There is a slight ticking to it.
It's a 2014 Cherokee Limited 2.4 4 cyl.
I should add that I did get a p1061 code that popped up and hasn't come back. But the misfire code has returned.
There is a rocking to it
Thanks. Hmmm, code P1061 means : 'Cylinder No. 1 oil supply solenoid valve stuck.'
What I'm reading on that isn't encouraging. We don't see many problems on this forum with the 2.4L, except oil consumption (low oil issues) and sometimes motor mounts.
Could be you'll need a new 'brick' (aka MultiAir actuator).
How is your oil consumption, if any ? Mileage on that Jeep ?
