Cracked Oil Filter Housing
5K views 4 replies 5 participants last post by  sanghill
When you get the oil filter housing replaced ask to keep the old one.
Clean it up and determine if the housing is actually cracked or possibly the O ring(s) were leaking.
My guess is if there is not any coolant in the oil and/or no oil in the coolant then probably the housing is probably cracked.
The new plastic oil filter housing comes with a filter and I think all of the sensors (2) and maybe the O rings.
The oil filter cover is screwed on to the correct torque during manufacture.
Put a stripe of paint on the cover and housing so you can see when it is installed correctly. (nail polish or touch-up paint).
Try to do this before a mechanic has the opportunity to over tighten the cap.
If you get the aluminum housing this discussion may be incorrect.
This is just a request, do it if you can.
