1 - 5 of 5 Posts
2014 jeep cherokee limited, 3.2.
Started recently , and only when the heat is on. Theres a smell, kind of chemical and slightly burnt.
Any input is appreciated
If it's kind of a sweet smell, it's possibly a coolant leak. Check the level and see if it's low, and see if the smell is present under the hood...馃槑
Does it smell when you use the air conditioner?
Check the cabin air filter, if it has been awhile might as replace it.
See if there is anything smelly in the housing.
Is the coolant level ok??
1 - 5 of 5 Posts
