1 - 15 of 15 Posts
had a check engine light for a cpl days. took it in thinking it might be an emissions situation. turned out to be an oil pressure sensor, altho the word switch also appears on my paperwork. regardless, the light is off. I'll test it with 450 highway miles in a cpl hours
Font Rectangle Material property Parallel Screenshot
Well, the good news is that that part number indeed shows an oil pressure sensor. They probably just have the description wrong in their billing system.
The bad news is that the genuine Mopar sensor only costs around $30 depending on where you buy it from. They gave you quite a markup there. And the average labor rate for auto repairs is about $150/hr. (some may be more, some less). $300 for an hour of labor sounds super steep to me.
Good luck on your road trip, stay safe!
I would check the valley under the intake and see if the oil filter adapter is leaking. Idk if intake has to be removed to replace switch or not. if does may as well do spark plugs
thank you
they actually had the car from 8:30am-1pm so I'll bet it took more than the prescribed time
I don't feel too bad. when I went in w/o an appointment I was greeted by 2 techs, 1 who was covered head to toe in mechanics dirt including oily hands. he took it in right away & the owner who wasn't much cleaner, came out in about 15 minutes saying they would need 3 hours & gave me a loaner w/o any paperwork. unheard of at a stealership
2015 Cherokee Trailhawk
Didn't know
Yes, the 2.4L is a very different engine than the Pentastar from the design to the actual operation. It seems like I've discovered more differences than I thought possible.
The main difference being one is an inline 4, and the other is a V6...😉😎
Discussion Starter · #11 ·
Got lucky w the 2.4 I guess the more I read the more I learn. Was also chatting w the shop owner cuz he mentioned the sixers & how some of them need replacing or lots of work. Asked if he knew about the 2.0T reliability cuz I was looking at 2019s but he was unaware & shared the usual turbo cautions
made it to NY last nite no problems & the light stayed off. Peice if mind is worth $400. I am bringing gear w me now should I get stranded road-side at night in temps in the 20sF. that time of year,eh?
freakin nite driving is a leap of faith. Just “keep it between the directional beacons” how does that song go?
the drive back north this afternoon should be a lot easier
I agree, peace of mind is worth $400, but that being said... (and not to rub it in)
It cost me $40 and ~20 minutes in the driveway, most of which was jacking the Cherokee up and down and removing then re-mounting the front passenger tire.
You just need a specific socket to remove the sensor that I found bundled with the senor itself on Amazon and an extension with u-joint for the ratchet wrench to reach the sensor itself.
I had to replace mine earlier this summer and I'm so glad I found the write up on this forum for it!
Discussion Starter · #14 ·
hehe gee thanks a lot :)
On the other hand, I didn't have peace of mind.
Since I "diagnosed" the issue myself (i.e. googled the code that came up), I took a chance that I was driving with insufficient oil pressure due to some other reason I wasn't aware of, that an actual mechanic would have known to check.
1 - 15 of 15 Posts
