I never had a reason to constantly monitor my car's voltage levels until now. I can confirm I see exactly the same behavior as
@Ocracokenc describes in my 2019 TH/E. Who knew?
I'm betting that if more of us monitor the voltage we would all see the same thing. Any 2014-2018 owners been staring at their volts lately?
I have a 2014 V6 TH.
Sometimes I will push the button to RUN and observe the battery voltage, if it is below 12V the battery needs to be charged.
The Jeep will still start just fine and I'll let it charge while I drive.
When the engine is running I'll check EVIC and make sure the charging voltage in the 13V to 14V range which is normal.
12V to 13V is not normal for a 2014. Over 15V and you have a severe problem.
It usually takes 30 minutes of driving for the oil temperature to get to normal.
Then I'll cycle through the other screens to make sure temperatures are increasing as expected and settle in on a "normal" reading.
When the needle is near vertical on the digital display the temperatures are normal. Anywhere in the "crescent" area is good.
I have been watching for 7 years so I pretty much know what "normal" is for my driving situation.
When I am off road I monitor the tire pressures almost continuously, if I puncture I tire I want to know about it sooner than later.
If I break a bead or blow a sidewall the TPMS will let me know instantly.
Coolant temperatures and transmission fluid temperature can get fairly high, especially in 4 low going up a steep hill in 2nd or 3rd gear.
It never gets over 90 degrees F on my hill so overheating is not normal.
Usually I run the A/C even if I don't need it to turn on both radiator fans all of the time.
I make sure the coolant reservoir is filled correctly.
My X2 Power AGM battery is all wrapped up in closed cell foam insulation and I have the "battery health" checked every couple months for free.
So I guess you could say I "have a thing" for battery voltage.
