Some people have had their PTU replaced and have noticed a difference in AWD operation post PTU replacement. My 2014 Cherokee had a PTU and RDM replacement less than 1 week after it was purchased new. Ever since the replacement there has always been a noticeable amount of wheel spin prior to AWD activation when using Auto mode. Before the replacement there was no wheel spin and the transfer of power was seamless with no front wheel slippage before the rear tires got power. When I purchased my 2016 I immediately noticed that it had zero front wheel slippage in auto mode on slippery surfaces. Driving my 2014 after my 2016 was quite frustrating as the 2014 really didn’t seem to be working as advertised. I theorized that after a PTU replacement Jeep changed the programming to prevent future drivetrain damage. Fast forward a few years and I had a PTU replacement in my 2016 however its AWD operation after the replacement did not change and worked as it did when new.
Using Alfa OBD I’ve been able to subject both my 2014 and 2016 to the same scenarios and data log to see the differences in the AWD operation and there are quite a few differences. I’m not sure I understand all the differences, but I’ll do my best to explain them.
I’ll refer back to this video of my 2016 Cherokee driving around in Auto Mode
The operation of my 2016 is what I would consider “normal” AWD system activates when slowing down and coming to a stop, upon starting again the rear torque value immediately climbs even with a small amount of throttle input (throttle input in % at the bottom of the video)
Now watch this video of my 2014
You can see the AWD system send power to the rear when slowing down and coming to a stop, however watch carefully as I accelerate from a stop at 1:52 you can see the rear torque value staying at 60nm but not moving up to a much higher number like in my 2016, You can see shortly after I get up to speed the value goes to 0 indicating that the vehicle is now operating in FWD mode (This shifting to FWD mode is the same as my 2016 as considered “normal)
At 2:22 I slow down and go around a corner, you can see again that the value of 60nm shows up as the awd system again is activated but as I accelerate that value stays at 60nm and then goes to 0 again as I get up to speed.
Now refer back to my 2016 Video at 4:37 where I slow down and turn a corner and accelerate you can see the rear torque value go much higher even though I’m using the same amount of throttle input. It looks like while the AWD system is active on the 2014 at low speed and when accelerating it doesn’t send hardly any power to the rear possibly explaining why there is a bunch of wheel spin on slick surfaces.
I can recreate this scenario over and over with the 2014. It appears that the system defaults to FWD mode even quicker and more often than my 2016 but when it is in the AWD mode its really not sending any meaningful torque to the rear wheels. A lot of throttle input does activate the AWD system and sends torque the “normal” way. You can see an example of this at 4:35 in the 2014 video. If you watch the 2014 video more you can see it showing values of 60,72,48,84 very small values when the AWD system is active but its not the same as the 2016 where the 2016 values raise immediately.
So there is a difference in the AWD system and its measurable, here is some more information and differences between the 2014 and 2016.
Here is the AWD system status for my 2014 when operating in 2WD mode
Operating in AWD mode
When in 4-low
Now my 2016 Cherokee Operating in 2WD Mode
Operating in AWD Mode
When in 4-low
You will notice some differences right away all in the Actuator position status
The 2016 has all the expected values for operating in 2WD mode, the 2014 has some really odd values
The actuator position status is different in every value, and in 1 value it even shows 4LO, not sure if its relevant to the difference of the AWD operation but its interesting none the less. The one value that in slightly interesting is the RDM Range Fork Position as being “BetweenHandN” I do see that on my 2016 but only DURING a shift in to low range. As see here
Now my 2014 Shifting in to low range
Here is my 2016 shifting through the selec terrain modes while driving
Here is my 2014 Shifting through the selec terrain modes while driving
I can’t really explain why there are such differences in the operation between the 2 vehicles but there is a difference in how the AWD system activates on the 2014 and it is measurable. I’m going to try and have a chat with my dealership and see if they can provide any additional information, although I’m doubtful they will give me anything. I’ll need to do some more research to see how/why everything is so different between the 2 vehicles.
When in 4-low
When in 4-low
