Hi again,
Having @
JeepCares involved can help at the dealership, for sure.
Can you check one quick easy thing for me ? If you scroll through the center display menu, you should get to a screen where you have a message about why ESS is not functionning (when that indicator light is On). That menu would be : press *down* with your left thumb until you get to a screen with an ESS message. Write it down and let us know, if possible.
About long lasting harm : with this specific problem, it is unlikely. As stated before (back in June), the problem is possibly linked to the intelligent battery sensor, and that sensor's function is to monitor battery health, to allow ESS to activate. It also helps with charging, ddepending on battery state, but charging occurs anyway, without the battery sensor's input, so I wouldn't be too worried. But getting it resolved is a good idea...
If you want to get things moving with the dealership, ask them to check the IBS (intelligent battery sensor) with their wiTECH machine (that's their fancy scanner tool). There is a procedure with that tool to check on the IBS ; quick and simple test...
