1 - 13 of 13 Posts
How do you run the power wire in a 2015 Jeep Limited 3.2? Is it all the same for the Cherokees 2014-?
I am trying to figure out the best way, and how to run it. I don't want to mess up.
Does anyone have pictures of where you ran your power wire?
2015 Cherokee Trailhawk
I ran the positive wire through the opening in the engine compartment firewall - fused in line - and connected to battery positive, while connecting the negative lead inside the head unit cavity. I imagine this would be the same in any Cherokee.
Where was the opening in the engine compartment? Can I get some pictures please?
It's down behind the brake pedal, you can find it with a flashlight. Be careful if you pop it out and not drop it somewhere and lose it - they are not easy to replace.
I did not photograph the process, sorry. You'll be able to locate it, no problem.
Question for everyone....
  • Are you running your direct-to-battery aftermarket audio amplifier wires through grommet #1 or #2 in the photo below? I used #1 for the two wires I ran last year but it's real difficult because it's where the wiring harness passes through and as you can see in the photo, I had to stay to the far bottom-right to keep well away (nick any of those wires in the harness and it's a world of hurt).
  • If anyone has gone through #2, does the wire actually come out into the engine compartment or underneath it? (the angle appears downward when looking at it from the drivers floorpan)
  • Is there any other place other than the two below that anyone else has found that work?
Recommendations?
Light Motor vehicle Gas Auto part Automotive exterior
I used opening number one. And you're right - be careful there.
I also used it for the wiring for my front bumper mounted light bar to the battery and relays (high and low beam).
My Kicker Key tucked nicely up behind the glovebox, and I used the access labelled 2 to run the wiring to the Battery. Someone recently posted that they sliced some of the factory wiring trying to push through #1, so yes be careful there! :cool:
Reactions: Leems
Since it was a compact amplifier, I secured it behind and to the right of the head unit inside the dash. I tried to make sure they are not too close so as to share their heat generation. I can still easily get to it if needed by popping the head unit out.
I think we're talking about the same spot... :D:cool:
1 - 13 of 13 Posts
