So far no problems filling up. I set the pump to shut off automatically and the gas gauge always shows full. I've filled it two times so far.
Yeah to clarify, it's not shutting off because its full. I'm not attempting to top off. I realize every gas pump stops at the point when the tank is filled to prevent spilling over. I was thinking it was the pressure of the pump as well. The gas is def backing up quickly which is shutting the pump off. It's very aggravated happened at a bunch of different gas stations to. As long as nothing stuck or twisted leading to the tank. I'm gonna try pulling the pump out more.I've had the same issue - pump shutting off right after inserting the nozzle. It varies though from gas station to gas station. I think it all has to do with the pressure settings for the pump. If the pressure is too high the fill mechanism of the Cherokee doesn't seem to be able to deal with it. Our Motorhome has the exact same issue.
One of the solutions is to not shuff the nozzle all the way into the tank - try it.
I bet that will work for them!Back the nozzle out about 1/2 inch. I had a Honda Ridgeline that did that.
That is the solution. I did that with my 2013 Dodge Dart.Back the nozzle out about 1/2 inch. I had a Honda Ridgeline that did that.
This. My Silverado does this about every 3rd time I fill up. Back the nozzle out a bit and lock-n-load.Back the nozzle out about 1/2 inch. I had a Honda Ridgeline that did that.
