The ambient lamps are the puddle lamps and door pocket lamps. There's one under each footwell in the front and in the lower door pockets (that have the molded beverage holders).
And their very subtle.The build sheet for my '22 KL claims it is equipped with 'ambient lighting'. I have the dual control wheels to the right of the headlight knob, so it looks like it should be there, but the 'ambient' control doesn't seem to do anything when driving at night.
Anybody know know which lamps are supposed to be controlled by this 'ambient' system?![]()
Are they different in the different year models? My 2018 has an ambient light in each door pull cavity, each door pocket, in the footwells, and there is an overhead light (between the 2 map lights) that shines down onto the center console (shifter) area.The ambient lamps are the puddle lamps and door pocket lamps. There's one under each footwell in the front and in the lower door pockets (that have the molded beverage holders).
I think they are all the same. My 2016 Altitude and 2022 Trailhawk both have the overhead ambient light.Are they different in the different year models? My 2018 has an ambient light in each door pull cavity, each door pocket, in the footwells, and there is an overhead light (between the 2 map lights) that shines down onto the center console (shifter) area.
They're so subtle/dim, I was surprised they even bothered adding a 'dimmer' switch. Could they get any dimmer? 😂And their very subtle.
Thanks, that was exactly my issue. I had the control in 'parade mode'.For the instrument panel lighting, if roll the control to full bright and then keep going, there is a detent past full bright. That puts the instrument lighting in “parade mode” where they will stay on full bright even when the exterior lights/headlights are on. The ambient lighting won’t work when the instrument panel control is in that highest detent.
Learn something new around here everyday. I'm going to now call "parade mode", "raining during the day mode"!!! Now I'll be able to actually see the dash display during the day, when the lights are on in inclement weather...👍😁😎Thanks, that was exactly my issue. I had the control in 'parade mode'.
What I don't understand is why we need a 'parade mode' at all on our KL's. The car already knows if it's daylight or dark outside to control the auto headlights. Should be a trivial matter when the headlights are on in the day due to rain/snow, etc, for the BCM to decide whether or not to dim the dash.Learn something new around here everyday. I'm going to now call "parade mode", "raining during the day mode"!!! Now I'll be able to actually see the dash display during the day, when the lights are on in inclement weather...👍😁😎
That's what I just learned, so when it's raining, snowing, or any other lower visibility weather situation, the smart folks (not many left) should be running their headlights. I keep mine on auto all the time, but I also have the setting in the Uconnect set for the headlights to come on when the wipers are on, since it's usually not dark enough during the day for the sensor to turn them on, but the dash and the Uconnect screen were literally unreadable for old, half blind guys like me. I guess I never went past the click on the dial, and the dash was still dimmer on the highest setting than the normal daytime setting. Now I can completely turn off the auto/night dimmer. It's freaking brilliant. Not sure how I never found this feature in almost 4yrs, until today...LOL!!!😁😎There may be a simple reason, but I don't get it (and I'm simple).![]()
I know you can set the display modes in the Uconnect settings that control the display brightness depending on the mode: day, night or auto. You can set you preferred display brightness for both day and night and the auto brightness will dim the display based on the feedback from the light sensor.What I don't understand is why we need a 'parade mode' at all on our KL's. The car already knows if it's daylight or dark outside to control the auto headlights. Should be a trivial matter when the headlights are on in the day due to rain/snow, etc, for the BCM to decide whether or not to dim the dash.
