I've actually got an email in to them and am waiting for a response. It's been a couple days.Try the AlfaOBD Web site: AlfaOBD
The North American version of the Cherokee doesn't have the type of door (window) modules needed to work with Global Windows, so, not a limitation of AlfaOBD...I've got the bypass, no tire change... also no global windows down? What's TCM, and why would i want to change it? Last, I haven't needed a proxy alignment yet, should I just get the canbus blue adapter now? Thanks for helping me get started.
Sorry to jump in, but I have been reading various posts on using AlfaODB and I want to try it.
I have a 2015 North Edition, my minor confusion is what adapters, if any, are needed?
I see mention of the Blue canbus adapter, a security gateway bypass module and various flavors of USB cables.
Suggestions?
-BobC
Ok, so no windows down, no tire change.. I can turn the fog lights on with high beams... What else have you guys been able to do successfully? I can program a key, yes?
I also have an aftermarket radio that I bought, that has a screen for climate controls, but the seller doesn't think it can talk to the bcm. He has a cable. But he doesn't think it will be right. Can i build the cable and order the right canbus? Or, can I make the one I have align with my car? I'd really like to understand how to make it work. I did install it, of course, and the seller said the the steering wheel controls should work, but I couldn't figure it out. I didn't try anything with alfa yet, cause I didn't have it yet. Am I correct in believing that with alfa I can get this radio to integrate successfully?
Thank you for the information, now to get the software and I will order the OBDMX+ just to be safe. Would hate to be trying to work on the KL and not have the proper adapters!2015 does not have a security gateway so no bypass needed. May or may not need blue canbus adapter, some do, some dont. Will need a supported OBD2 dongle that works with the software. i use the OBDMX but its been replaced by the + version.
No, you cannot use it to program keys (at least as far as I know). Now in regards to the aftermarket radio. I'm not sure on that one. Usually in order to retain factory functions with an aftermarket unit, it will need to be one that supports idatalink for one of the maestro units. Now I'm not saying there are not some aftermarket units that can work directly, its just a little out of my knowledge base. Unfortunately with the KL, there is just not much that is able to change. I even tried changing my backup lights from bulb to LED when I upgraded, and that didn't even work, had to install resistors to clear the bulb out warning. Alfa in the KL is mainly used for fixing things. I used to use it for diagnosis as well, but actually found the obdlink software was better/faster for most things when I didn't need to actually command the KL to do something.View attachment 219774
Its easy to pop out the center consol. I just did it installing my Ham radio. First pull out the rubber part in the cubby. Then pop off the flat piece right about it. Then the whole thing just pops out.
