1 - 20 of 30 Posts
Hi, I was wondering if there’s a decent or good looking way to have your light bar switch installed inside of your KL without seeing the annoying wires.
Also, I lost my rubber seal and I think they’re on the skid plate anywhere, is it important to have it back and sealed?. Does anybody have a suggestion for this matter ?
Help please.
I couldn't figure where to mount a switch or how to run wires thru the firewall so I used a Pilot 4 channel wireless remote.
Mounted the base unit on top of the front left wheel well and got 12V from F65 in the PDC using a Bussman ATR add-a-ckt fuse.
It was the only place I could find a fuse that was only hot when the Jeep was running.
Since there are 4 circuits you could control 4 separate sets of lights.
You will need relays to operate the lights.
I wear the fob on a neck strap along with my other Jeep fob so I can find it.
There is an on/off switch on the fob to preserve the battery in the fob.
I was concerned that RF would not get from the fob to the base unit but it works fine even without extending the fob antenna.
Only one fob will only work with one base unit.
Has been working for a while and works for me.
Refer to this post for the schematic: Driving lights
Update if you can figure out a way install a switch.
Musicians use a foot operated switch for something, I would like to do this again.
I used it in my SAAB so I could blow the horn without removing my hands from the steering wheel.
I've seen a post on here, cannot remember where. Dude cut a panel to fit inside the little door bottom left of the steering wheel. With enough patience you can find a way through the firewall on any vehicle.
On the drivers side firewall there is a rubber plug you can remove and route your wires through that. I ran my ham radio power wires and antenna cable through it.
Found it from the interior. Will need to split some small diameter tubing to go over the sheet metal hole.
Maybe I can find the engine side from underneath the Jeep.
I have a switch, relay, and light setup on my 19KL. Ill show you guys some pictures of my setup shortly. :)
Update:
So thanks to a helpful YouTube video I was able to do the installation of my lights.
Basically ran my wires through the firewall of my KL, into my relay and fuse box under my driver seat which all connects to my switch. The switch ended up being positioned underneath the day light running light control knob.
Link:
Let me know if you guys have any questions!
210630
210628
210629
210627
How has worked out for you? Pros cons or anything you would have done differently now?
Sent from my iPhone using Tapatalk Pro
Thanks for asking!
So this was installed Sep 2019.
Personally I am in love with my setup. So far I don’t have any cons. I used to have a relay with a switch which died on me after like 5 months. Then instead of purchasing another one I decided to do this because I wanted a learning experience.
Only thing I will say is if you do your power block and place it under the driver sear, I would highly recommend to place maybe one more relay for any future need and wire it up. When the need comes its less of a hassle to wire the new accessory since theres little space. Or you can leave maybe a foot of slack coiled to just bring it out below the seat.
Last question. Rocker switch pin type? I’m looking at it here pin.
Bought this rocker...
FXC Waterproof Marine Boat Rocker... Amazon.com : FXC Waterproof Marine Boat Rocker Switch Panel 4 Gang with 4.2A Dual USB Slot Socket + Digital Voltage Display + Cigarette Lighter LED Light for Car Rv Vehicles Truck : Sports & Outdoors
Back...
Ill create a quick diagram to show you the install if you like. Even though everything was cabled on my rocker I bought, I decided to just take it all apart and re-wire it myself.
Back...
That is definitely the coolest switch box ever!!! Does it fit well in that spot on the left side of the steering wheel under the regular light switch? I see your pictures, and it looks pretty good.
Cool, looks like you made good use out of the useless cubbyhole!!! LOL
If you don't have a sunroof, an option is to get an overhead console that does have the sunroof buttons, remove those buttons and fit your own instead:
210782
These are inexpensive standard electronics toggle switches with weatherproof caps. I also fitted an LED for each switch to indicate when it's active.
I went a bit overboard on the indicator functions using multi-colored LEDs to indicate both off, on, and active "modes". But I could just have hooked the LED up to simply show when the switch it toggled on, like most illuminated switches do.
Help please.
211496
211497
1 - 20 of 30 Posts
