been toying w// the same idea. so I have a cpl thoughts
drill new holes in bracket to match holes in bumper cover
there should be 4 decent holes
I was thinking one could drill additional holes, perhaps 8 so that there'd be more support
chuck the license plate holder, just use the plate & light bracket
there is a small space between the bumper cover & bumper
one would have to use those short stubby license plate screws
drill pilot holes in the plastic but the diameter is important
was reading a product page, I'll include the link below
it has a bracket which is shaped to fit our bumper cover better
they supply bolts meant to go thru to the bumper w/ nuts
this is probably the best solution
I wonder if the bumper cover would look dimpled if squeezed by the bolts
brackets
I have a 2014
24" bracket
THOSE BRACKETS COME WITH THE BOLTS
467eff_972c8956a0b546d29c564c1ba336b547.pdf
Mounting Info
16" Front Bracket will accommodate either 2 ea. 4" pod lights or a Curved Light Bar. Please note there are several different mounting types for various light bars on the market. This bracket is designed for mounting 2ea. 4" pod lights or a curved light bar in the 2 outer mounting holes as long as the mounting bracket holes on the light itself measure 12" C-C. Mounting a straight light bar will require additional modifications. This bracket mounts through your front bumper in place of OEM front license plate bracket. Mounts easily by simply re-drilling through the 4 original bracket holes into steel bumper behind plastic and mounting. Please make sure to check behind bumper for wiring harness and protect/ reposition the wires before drilling to prevent melting or damage. This bracket is deigned to be mounted with the OEM Plastic License Plate Bracket, but if you do not have one it can also be mounted without the OEM bracket by simply shimming out the license plate approx. 1/4."
