Back in Nov 2016, I purchased a 2014 Jeep Cherokee Trailhawk which at the time had over 51k miles on it. As of this writing, and after 4 years of ownership, I am over 141k miles, and I'm happy to report my experience has been for the most part pretty good. To be clear, prior to buying this, I already knew of the early transmission issues, plus that it's usually a bad idea to buy the first year of a new generation of a vehicle. What could possibly go wrong?
...not much quite frankly.
Since my purchase, I have tracked every gas fill up, every part I've bought, every oil change, and any dealer, or mechanic visit for issues, or maintenance through a spreadsheet. Keep in mind I will not be including registrations, or insurance numbers for this.
2016-2017
Gas: $2425.18 (some cost includes gas station car washes)
Parts for Jeep: $1085.22 (Rotors/Pads Front & Rear, Oil + Filters, Tires + Mounting/Balancing, Wiper Blades, Air Filter)
Dealer Visit: $128.71 (fix leak in sun roof, and trans recall)
Operating Cost: $3639.11
2018
Gas: $3742.61 (some cost includes gas station car washes)
Parts for Jeep: $299.39 (Oil + Filters, Wiper Blades, Rear Brake Pads, Spark Plugs, Car Washes)
Dealer Visit: Bad Oil Filter Housing, covered under PT Warranty
Operating Cost: $4042.00
2019
Gas: $3494.55 (some cost includes gas station car washes)
Parts for Jeep: $401.83 (Oil + Filters, Cabin + Air Filter, Wiper Blades, Battery, Driver Side Seat Plastic Cover, Headlight Bulbs, Cellphone Holder,)
Mechanic Visit (Maintenance as a result of Coolant Leak): $1492.97 (Serpentine Belt, Tensioners, Crossover Pipe, Idler Pulley, Coolant Flush, Water Pump, Thermostat, and Gaskets)
Operating Cost: $5389.35
2020
Gas: $1781.10 (some cost includes gas station car washes)
Parts for Jeep: $1858.64 (Oil + Filters, Laptop Mount, Front Seat Covers, Rotors/Pads front & rear, Sway Bar End Links, Rear Brake Carrier Brackets, Tires + Mounting/Balancing)
Dealer Visit: $399.95 (Transmission Recall, tire rotation + alignment)
Operating Cost: $4039.45
To break it down between gas, and parts + labor (if my math is correct):
Total Gas: $11,443.44
Parts + Labor: $5,666.72
Total Operating Cost after 4 years: $17,110.16
The only real issue I've had was a crack in the Oil Filter Housing, which I'm sure many of you know are prone to leaking over time because they're all plastic. That was replaced at 98k miles just before my Powertrain warranty went out, so no payment was necessary. Other than that, it's been mostly routine maintenance, plus all the gas for driving.
That's not to say everything works right now though...
4Low does not engage due to what the Dealer said was an "internal failure" of the PTU, and would require a new unit. I opted not to replace it last year as it would've cost me $2300 parts & labor (an Indie Mechanic could probably do it for 1500 all in I would think). Despite this, all other drive modes work as intended, so I haven't had much of a reason to replace it yet. Maybe once 4WD actually fails, then I'll get it replaced.
The auto Liftgate also no longer works as the motor is burned out according to the dealer also. That though, I plan on replacing this winter myself as the motor strut is a couple hundred bucks (they quoted me over $500 parts & labor), plus a new gas strut I'll get as well.
The only other thing that is "broken" is the dial that turns the headlights on/off. One time when I was exiting the Jeep, my knee hit the dial, and pushed it into the dash. I was able to retrieve it, and it still works, although it could be pushed inward again. Only the wiring has been holding it up, so I'll replace that probably at some point.
Overall, I've been very happy with my Jeep, and it's proved extremely useful. I've towed a few times with it, gone off the beaten path on jobs, pulled out cars, and tree stumps, hauled lots of equipment, and items. It's been a very dependable vehicle, and I'm glad to own it. It's pretty much all stock minus a few interior additions such as seat covers, a laptop mount, cellphone holder, and a dualcam dashcam (the dashcam was an Xmas gift hence why not included in total cost).
It doesn't do everything great though. The transmission is finicky as the early models are, the bluetooth function can be weird at times as the steering wheel next/prev track buttons don't always work, and I wish cargo space was better. I've had to make some concessions when hauling stuff (I wish I could mount the spare tire on the rear hatch like you can with the new Land Rover Defender, or the earlier Toyota RAV4's, but alas).
One thing I'll point out is since this is a work vehicle on top of being my daily driver, I do get reimbursed mileage when on the job. Since I bought the Jeep, I've received over $22k in expenses for mileage, and as a result has paid for everything, including all gas since I've owned it.
As for this year, I'll be hitting 150k miles, and that would be a good time to replace some worn out suspension components such as shocks, and control arms. I'll also replace the Front Brake carrier brackets as those are quite rusted out, and the guide pins do not move like they should. Engine and Transmission thus far are holding up quite well, so not much to complain on that front. I'll probably be hitting over 160k or so by the end of this year.
I could go on, and on, but I think that's good enough for now. I might revisit this again when I hit 5 years, and see how things go. Until then, Happy Motoring, JCC!
2016-2017
2018
2019
2020
