1 - 11 of 11 Posts
1st of all thanks for reading. I currently have a 2019 TH with the 6 cylinder with tow package. I had a question on towing with the TH.
I recently purchased a 2022 Rockwood 2716G popup. Dry weight of this is 2800lbs and 360lbs tongue weight. I know the limits of the Cherokee is 4500lbs and 450 hitch weight.
Stupid me, as a newbie with campers, listened to the rv salesman who told me,yes,your jeep can tow this safely as it’s under weight. Of course I didn’t realize the 360 tongue weight is the advertised brochure weight. No one seems to be able to answer if this weight includes the 2 propane tanks or not.
My question is, I am stuck with this purchase now, and I’m stuck with the trailhawk. Is the 450lb tongue limit the actual limit the hitch on the jeep can handle? Meaning if it’s actually 460lbs now I take a chance of the hitch falling off? After much research, it doesn’t look like I can add a wdh to the popup due to the dual propane tanks getting in the way, plus if I’m close to 400 as is, any wdh is certainly going to put me over 450.
I might also add, I drive alone, so payload is no issue as it’s just me. I also towed it home from the rv store two weeks ago, pulled it like it wasn’t even attached. I do have a brake controller. My trips are all 60 miles or less. I’m just afraid I’m going to do damage to the Cherokee long term by pulling this large popup.
Any suggestions would be great, and also if anyone knows if the 360lb brochure hitch weight on the Rockwoods include propane or not? I do have a hitch scale on order so I know for sure. Thanks again for helping.
I thought a loaded propane tank weighed around 40 lbs. (80 lbs. total for two) If so, you would still be under the tongue weight recommendation. Are you planning to do a lot of off the grid camping where you would need both propane tanks?
Hey thanks. Actually not. Depending on how the weight goes when I get scale, 1st thing to go is an extra tank. I still don’t think I can add the wdh bracket though. Any idea If the jeep can handle hitch weight under 450lbs?
2019 Cherokee Trailhawk Elite 2.0T
Since the weight is listed as dry weight, you should assume that the hitch weight is also dry. To keep weight off the hitch, load more towards the rear of the trailer being careful not to put too much weight behind the axle.
I towed a Forest River Cherokee Wolf Pup 16BHS with a hitch weight advertised at 377 lbs. and never had any problems. I did buy a weight distribution hitch with sway control to pull the trailer.
you can take weight off the tongue by mounting propane cylinders not on the tongue. Sounds stupidly simplistic but its very much the case. I cant see a popup being too much for your cherokee with weight near the axle. the simple length of the tongue is why you can probably lift it with nothing in the camper , i presume, at least it not be crushingly heavy.
Also, have you actually gotten a proper hitch scale? Because 40 pounds at the front of the trailer not at the tongue isnt going to be 40 pounds on the tongue especially if the axle isnt that far away. weight behind the axle is also going to pull weight off the tongue but you shouldnt really attempt to ballast the tongue by adding behind the axle, im just saying you should consider a tongue scale that can be bought to determine how much is on the tongue. Also, if you have the trailer perfectly level, or is it slightly sloped back, or is it pinning downward to the hitch? A perfectly level trailer is gonna have more on the tongue than one thats tipping ever so much back from having it hitched higher up. A picture of how your trailer looks on your hitch on level ground could help us provide thoughts on it.
You will be fine, don't worry about it. If you have a sagging problem, just get a weight distribution hitch and you will be good to go.
I went to the Rockwood site and found a 2716F. You can look up your specific model but I doubt it's much different.
The trailer had a nominal hitch weight of 360 lbs. The UVW (Unloaded Vehicle Weight) is 2854 lbs. A neutrally-weighted trailer (50% of weight in front and behind axles) would have a 0 lb tongue weight. Of course, that would tow like crap. Industry standards are somewhere between 10%-20% loading toward the front for optimum towing. So, your 360 lb tongue weight is your nominal tongue weight (360) divided by your UVW (2854), or about 12.6%. This is within the range of industry standards.
So now you need to add propane, food, clothing utensils, water, and everything else you need for camping. Your total CCC (Cargo Carrying Capacity) is 506 lbs. So the total weight of the trail at maximum capacity is UVW (2854) + CCC (506) = 3360 lbs. Well within the towing capacity of your vehicle. You also need to consider your black and gray tanks, though those are usually either 1) offset by the water you use or 2) dumped before you travel. So it wouldn't a common situation to run with full fresh, black, and gray tanks. I think your trailer has a cassette tank that is for both black and gray. The point is you only need to consider a full fresh-water tank.
Manufacturers generally assume the weight distribution will remain roughly the same between dry weight and fully loaded. So it is safe to assume that your tongue weight will still be in the ballpark of 12.6% +/- a couple of percent. Your fully loaded tongue weight with a full load, including propane, should be about 424 lbs +/-. That is still within your towing limits.
Even if you run around with an empty trailer but full propane tanks, the weight is distributed to some degree between the tongue and the trailer axle, so you are not puting the full weight of the propane on the tongue. That would probably only be when you go to fill the tanks before a trip anyway so distances are short.
Remember you need to look at your placard on the driver's door to see what the maximum load is. In my case in 900 lbs.
Per the owner's manual:
Consider the following items when computing the weight
on the rear axle of the vehicle:
• The tongue weight of the trailer.
• The weight of any other type of cargo or equipment put
in or on your vehicle.
• The weight of the driver and all passengers.
So you need to subtract the tongue weight from the total capacity to figure out how much you can put inside your Cherokee. With a fully loaded trailer, you only have about 476 lbs of passengers and equipment inside the car (assuming your capacity is 900 lbs). I would bet most people don't even concern themselves with what they are stuffing in the car.
The funky thing about the weight distribution is the limit in the owner's manual is on the GAWR (Gross Axle Weight Rating) for the rear axle (also found on the placard). But the total capacity is against the GVWR (Gross Vehicle Weight Rating). Your load will be biased toward the back of the vehicle when towing. Technically you need to consider the maximum capacity against the GVWR and the GAWR, but you are within the limits with the trailer. The only thing that might exceed the GAWR is if you put something very heavy in the back of your car and you and your passenger are feather-weights. Even then it would be hard to exceed the GAWR. In my case, the GAWR for both front and rear is 2805 lbs, but the GVWR is 5500 lbs. The total axle capacity is 2805 + 2805 = 5610 lbs. Most cars are weight-based toward the front because that is where the engine and transmission are. So to shift the bias from the front to the back to the point that you exceed the GAWR but are still within the GVWR would be somewhat unlikely. Not impossible, but not worth worrying about IMO.
Bottom line is - don't worry about it. Even if you stuff your trailer to the max you are still within the towing limits.
A bit long-winded, but I hope this helps.
There have been several people on these forums towing campers in the 3,800 pound dry weight, that aren't even pop ups. If you are worried about the extra tongue weight, get a weight distribution hitch. I think you are overthinking it. With a weight distribution hitch, you will also have the advantage of sway control, but with a low profile camper like a popup, you really shouldn't have an issue. The biggest issue with towing is just the range. Its already a small gas tank, so the reduction in mpg really hits hard on the range.
1 - 11 of 11 Posts
