1 - 20 of 53 Posts
Working on replacing a starter for a 2.0l and im trying to find the starter. Heard some people take the intake off to do this job. Any suggestions to get this done?
If your Jeep is still under factory warranty why would you want to remove the starter??????
Many '19s (released mid 2018) are out of the 3 year warranty...
On the 2.0 it's from below... If you have a 4X4, you'll need to remove the transfer case. (it's the 2.4 that may require removing the intake). :cool:
What makes you think that the starter is bad to begin with??? Starter failure on our Cherokees is EXTREMELY RARE, in fact almost unheard of...😎
Discussion Starter · #7 ·
Automotive tire Flash photography Motor vehicle Grey Thigh
Tool Wood Font Tints and shades Rectangle
Had took some picture of the underside. This is what I thought the starter was but wanted to make sure before I went ahead and started taking stuff off
Discussion Starter · #8 ·
Car won't crank for him he said. He got the battery changed with a new one and didn't fix the issue for him. Alternator looks fine on the car when I got a hold of it.
Check the connection at the starter, and all grounds. Like I said, these starters don't just fail...😎
And the Starter related fuses/relays...
Even new batteries off the shelf can be bad, especially if they aren't high spec...
Yep, my money is on he's going to buy the $400 starter, do all of the massive work to get it out and the new one in, put it all back together, and it doesn't fix it. The first clue should be the lack of starter related posts on the forum, and the ones that are, it's always been something else, usually bad connection or batteries, like 98.7% of the time...l wish you luck though...😎
Best suggestion (other than taking it to a shop), is to get an online service manual subscription from Mopar's Buy Mopar Approved Service Information and follow the factory diagnostics from a to z... :cool:
Discussion Starter · #16 ·
When your just trying to get an answer on where the starter is and people come in with all this stuff that I've already done. But ay people can't read I guess
Plus starter is 60 dollars at local shop so couldn't care about price.. 😎
Wow. Change 'er up then. Good luck.
Ah, didn't realize! Glad your friend is in such good hands! Have fun! 😏
Discussion Starter · #20 ·
I mean I asked one thing told yall I checked the other but no one wanna give an actually answer to the real question. So idk seems like not much😐... Atl the only one that wants to give an answer. Appreciate the suggestion but an answer to the question would be much better
1 - 20 of 53 Posts
