21 - 28 of 28 Posts
Reactions: NScherry
Discussion Starter · #22 ·
Thanks for the quick reply @AtlCade69 . Something else I just thought of though; is it 2 ohm or 4? Got my eye on a Rockford shallow mount 150W.
Reactions: NScherry
Discussion Starter · #24 ·
Perfect! What I thought. The RF is 8", 2ohms to each coil, 2.5" depth, 150W RMS. Thanks again @AtlCade69 !
Reactions: AtlCade69
Discussion Starter · #25 ·
Ordered an 8" Alpine dvc 2 ohm instead. Should have it in 7-10 days. Will post the results...
Discussion Starter · #26 ·
Well, after a long wait on shipping, finally received my 8" Alpine sub. Install was two hours, not as bad as I anticipated. The factory "sub" is a paper cone and fairly light weight. I have not had a chance to push it yet, but my initial reaction at lower volumes is that this Alpine produces nice clean bass. A nice crisp thump versus the "clunk" from the factory unit.
Hood Automotive lighting Automotive tire Motor vehicle Vehicle
Automotive tire Automotive lighting Bag Bumper Hood
Automotive tire Product Automotive design Motor vehicle Tire
Automotive tire Motor vehicle Automotive design Rim Automotive wheel system
How well did the Type S fit in the factory enclosure, did you need to modify it or any thing else to fit it?
Discussion Starter · #28 ·
Dropped right in. Only thing I had to do was drill new holes for the Alpine flange, cut off the factory plug in adaptors and tin the wire ends, plug the hole in the box where the factory uses a torx screw that threads into the factory sub. I could have modified the Alpine to take the support screw, but felt it was unnecessary, we'll see, LoL.
21 - 28 of 28 Posts
