Don’t hold your breath, but there may be a a new recall. I don’t keep up on this stuff so read for yourself.
No. Lets say Joe-Bob was installing the snap rings right and right next to him Jimmy-Bob (Joe-Bob's cousin) was installing the rings wrong. Another scenario Work station 1 got snap rings from one vendor and station 2 received rings from another vendor. That's if it was a vender problem and not an install problem. We will never know how or why they picked the VIN's that they did.So shouldn't the recall be universal?
AAM is the one and only manufacturer and supplier of the Ecotrac , their is no other manufacturer.
Sorry maybe I was too focused on it being only 1 manufacturer, they do have multiple plants, so could be that , I’m not clear on that. Also as @Fj4080 said in above post 😎So shouldn't the recall be universal?
Based on how often they break it's like they licensed production to a glass manufacturerAAM is the one and only manufacturer and supplier of the Ecotrac , their is no other manufacturer.
The recall window is from the day Jimmy-Bob started work at AAM, and ended the day he was fired.No. Lets say Joe-Bob was installing the snap rings right and right next to him Jimmy-Bob (Joe-Bob's cousin) was installing the rings wrong. Another scenario Work station 1 got snap rings from one vendor and station 2 received rings from another vendor. That's if it was a vender problem and not an install problem. We will never know how or why they picked the VIN's that they did.
Someone is offended by all this Joe-Bob, Jimmy-Bob stuff.....The recall window is from the day Jimmy-Bob started work at AAM, and ended the day he was fired.![]()
So you don't have ptu issues?Mine's a 2014 and apparently not from the factories that were creating the PTU issue.I'm waiting patiently...
SCV 4WD can come on for many different reasons/failures. The actuator is a different failure than the recalls are for .Okay, so the dealer here in New Zealand is telling me my car has the dreaded DTC C14A7-97 error code.
They say "This is an electrical DTC referring to the PTU motor / actuator that engages 4WD via the PTU. This does not cause loss of drive; it only inhibits the engagement of 4WD."
Does this sound credible? That it's purely concidence that my Cherokee TH has the SVC 4WD error as described in the recall, but it's a different fault?
Hey Peter,Okay, so the dealer here in New Zealand is telling me my car has the dreaded DTC C14A7-97 error code.
I'm pissed. My 2019 cherokee has been parked since last fall (2024) because 4wd light on. Borrowing cars from grown kids getting old. Jeep says my vin not in recall I have the ptu problem and they won't acknowledge. Took excellent care and lower miles. Not sure what to do. I live in Minnesota so need 4wd in winter.
[/QUOT
[/QUOTE
I’m having the same issue with my 2019 Jeep, my PTU literally exploded while my daughter was driving. Jeep just says my vin isn’t part of the recallI'm pissed. My 2019 cherokee has been parked since last fall (2024) because 4wd light on. Borrowing cars from grown kids getting old. Jeep says my vin not in recall I have the ptu problem and they won't acknowledge. Took excellent care and lower miles. Not sure what to do. I live in Minnesota so need 4wd in winter.![]()
Is yours the 2-speed PTU (has the 4WD LOW setting)?I'm pissed. My 2019 cherokee has been parked since last fall (2024) because 4wd light on. Borrowing cars from grown kids getting old. Jeep says my vin not in recall I have the ptu problem and they won't acknowledge. Took excellent care and lower miles. Not sure what to do. I live in Minnesota so need 4wd in winter.
Not only can you get it fixed, if the recall is expanded you might be able to get the repairs reimbursed. Per 01C notice to customers:@jeanmnskomars
Not in the recall doesn't mean you can't fix it.
Many of us have been looking for something to explain the issue other than "an improperly seated input shaft snap ring" as the recall said.I researched and found the snap ring used for a few years was sourced from a different supplier and may be a slightly different thickness. The problem disappeared in 2019 with a return to the proper part.
“Facts is facts."
