2015 Latitude 4wd, 3.2, 120K miles. Brake job at 118K using Chrysler OEM rotors & pads.
Developed a noise when braking, coming to a stop. Or stopped then letting off/on/off the brake. Doesn't do it first 5-10 city miles. It has to be warmed up to get the noise.
Only when articulating the suspension. I get a squeak/groan. Similar to that of hot brakes at a red light where you let the vehicle creep off the brakes and it makes that groan or chatter but I believe its suspension. I can bounce the suspension when parked...static and I don't hear it.
I did the brake job 2K ago. I did inspect things at tire rotation 1K after the brake job and it all looked ok. This noise is a recent development.
I’m fairly confident it’s not the brakes. Side Note: I have had to brake very heavy a few times within the last 2K miles as I drive a new way to work which is filthy with deer.
Struts? Anti-roll bar bushings? Don’t know…haven’t crawled under it to give it a good inspection yet…currently tooo cold.
Does anyone else experience this noise? Have you determined the source?
TX
TX
