Hello:
Very little to no power to the vehicle. If I try and use a booster, I can use the remote and unlock/lock, I can put accessories on. Without it there is no power. I tried a swap with battery from Caravan and have same symptoms/will not start. Battery conditioner shows battery is fine (good voltage, capacity).
i took the car to town Sunday morning, parked it and next morning it had no power/would turn on.
I’ve been able to get it started momentarily but it stalls within a few seconds. Most of the time it won’t even start.
i ran ODB scanner and got the following codes
U0101 lost comm with TCM
U110A lost comm with SCM-CAN-C
U110F lost fuel volume message
U0131 lost comm with PSC
U0140 loss comm with BCM
U1411 implausible fuel volume signal
P0480 cooling fan 1 control circuit/open
P0123 TP sensor/APPS Circuit High Input
I’ve checked the wires which look ok from what I can see; connectors also ok. Fuses look ok and no sign of damage to most relays in fuse box.
Anyone can point me to a common problem the combination of codes would point to?
