So, it all started driving calmly down the road....
The car shuddered, the check engine light came on, and the vechicle notified me "4x4 disabled"
I pulled over, grabbed my OBD reader, and pulled the codes:
U1424 (control unit 18)
P0390 (camshaft position (CMP) sensor B, bank 2 - circuit malfunction. Control unit 10)
Car limping, doesn't really shift above 4th gear, up to 35mph...
Boiled down to the $36-50 cam sensor, but the one under the intake manifold.... lacking time, valuing my transportation, I had the shop diagnose and replace it. $286 parts + labor
Unfortunately.... they called me, and it didn't fix anything.
Now, it shows:
U1424(00) - (control unit 18. Status: Test Failed (current drive cycle) pending, confirmed, test failed since last DTC clear, warning indicator requested)
P0349 (CAmshaft position sensor A, bank 2 - circuit intermittent. Control unit 10)
So... the shop told me I need a new ECM for $1100. I've deduced that in Jeeps, ECM = ECU = PCM --- can someone double confirm that? I always called it an ECU in the Honda world... I've found ECM's for as low as $230 pre-programmed, and the dealership here charges $225 for programming.
I then called Jeeps R Us, a local shop, and talked to some guy who worked there 30 years... he was like "hmmmmm.... noooo, noooo, that doesn't make sense, I mean, I've worked here 30 years, the ECM's don't go bad.... that's weird.... I would say get a second opinion... take it to another shop nearby". They're about 30 minutes from me, I'd need to have the car towed, but might do it just becuase of their experience... I have AAA so it should be covered under my membership.
I've searched for a couple hours, on these forums, and google in general, and.... man, there's not that much out there on these KL's, is there? I found this thread, but no answers... Maybe I was spoiled in the Honda game... but man, I've searched and really haven't managed to find this issue occuring anywhere else.
So, at this point, I could replace the Sensor B in Bank 2, it's super easy to get to and only $30.... but if it's something electronic, those might be just fine, non-issue.
Anyway... if anyone has any insight into this, please let me know, I'd be super appreciative! I'll post tomorrow morning when I get the new sensor into Bank 2...
Thanks!
Now, it shows:
Thanks!
