Hi All,
I'm new to the forum and am posting because my wife's Cherokee has a problem that has me very puzzled and am hoping someone here can provide some guidance.
We have had the vehicle since new it currently has a little over 70 k miles and until last week has been trouble-free and performed flawlessly. We had the Cherokee's front end aligned after installing new tires on the front, the back tires were not replaced and the rear was not aligned.
The transaxle in this ride has always had silky smooth upshifts. Downshifts when coming to a stop can be felt but nothing extraordinary. There are no outstanding recalls on the vehicle, and it has never been part of any of the past trans recalls. We seem to have gotten a good one!
Now the car has what I can only describe as a surge or a slight drivetrain bump when driven between 30-40 mph, you can feel it in the seat of your pants, under the trans tunnel, though it does not seem to occur while shifting.
There is no noise associated with the surge/bump. When this occurs there is no change in the rpm, the transaxle doesn't bang or make any noise at all nor does it shift hard. The vehicle's performance is not hindered in any appreciable way.
No fault lights light on the display. We viewed the transmission temp while driving and the issue started when the trans temp was at 95F so I don't believe it's heat-related. Terrain does not make any difference on when it happens, It will occur when diving on level ground or going uphill, under normal acceleration, or hard.
Visual inspection has revealed nothing out of the ordinary, no loose parts no leaks.
Any ideas?
Any Assistance is greatly appreciated
thx
J
Any ideas?
thx
J
