Check the tightness of the hose clamps you removed and replaced. Sometimes they need to be re-tightened.
Make sure the thermostat gasket isn't leaking.
Could it be leaking from the water pump.
Is it possible for the serpentine belt tensioner to leak coolant?
Where you SEE the coolant is usually nowhere close to the actual leak.
Do the radiator hoses look ok? Maybe it is time replace all of the radiator hoses and the serpentine belt.
Supposedly the coolant system does not require maintenance for 100K miles or 10 years, which ever comes first.
I am never going to replace my coolant or hoses. A couple times a year I remove the antifreeze from the overflow tank and refill it with 50/50 new antifreeze.
That way the chemical additives are maintained.
The Cherokee uses strange hose clamps. If you used screw type clamps that could be the problem.
My 2014 V6 TH looses a little coolant and I just top it up.
There may be some V6 coolant Posts on this Forum, but I haven't found them.
Well I finally remembered this one:
Unpressurize Cherokee
Mopar probably has some Seal Tabs that are compatible with Mopar antifreeze, if they work you are in luck.
Let me know what you eventually find, in 4 more years I may have 140K miles on my TH.
